Vegetable Face Sponge – Ideal for All Skin Types*
Manufactured from sustainable sources, these sponges are 100% derived from the konnyaku vegetable. A perennial plant which grows in countries such as India, China and Japan, this vegetable has been used in Japan as part of facial beauty regime for over a century.
Please soak in warm water for around 1 minute before first use. This sponge gently exfoliates the skin and can be used with additional soap/gels wash. Rinse well and hang to dry in between uses. Do try to use different parts of the sponge each day so that you do not end up with putting maximum usage in one particular area; this will help to maintain longevity of the sponge. Once it starts to disintegrate, please discard.
* Whilst this product is suitable for all skin types, you can test it on a small area of your arm 24 hours prior to use on your face.
Composition : Konnyaku(84%), Calcium hydroxide(1%), moisture(15%)
No preservatives used.
Customer Reviews
I am unable to use soap on my face, due to very dry skin and then I happened upon this truly exceptional sponge. No need for soap or products, just water! My skin has improved both in texture and dryness, I use it all the time and to even remove makeup. Highly recommend this magic sponge to everyone.Sandra Cheshire (4 Sep 2012, 11:37)
Write a reviewPlease enter a valid email address.
This field is required.
